This magnetic PCB clamp costs less than $1, and can be assembled in minutes from items at your local hardware store.
Funny - I was using something similar to mount a webcam on devices - never thought of adding another nut to hold things down. If you use 1/4"-20 bolts, the same setup will work as a camera/webcam mount. I'll be building more of these over the weekend.
Hey Dylan -- this is ridiculously clever! I've been looking for some of those fancy spring-loaded magnetic PCB clips, but this is so simple and easy I can't believe I never thought of it! Headed to Depot tonight to round up the hardware. Wrote it up for the blog, too, should publish soon. Thanks for posting this, very cool idea.
Thanks for the inspiration Dylan. I went and rolled a version of my own: https://hackaday.io/project/202216-another-spin-on-pcb-clamps
