Get a grip.
A project log for Another spin on PCB clamps
My old spin on PCBite magnetic PCB clamps are too hard to make. Motivated by a recent HaD post I did a much easier respin.
paulPaul 01/29/2025 at 01:230 Comments
So, in actual use, when you tighten down on the knob, it tends to grip the PCB and pull it along a bit, sliding it along the bottom surface of the PCB.
So I added a component: a washer made from EPDM rubber, cut from a bit of leftover garden pond liner (aka, roofing rubber).
I added a picture to the gallery to show it.
I cut about a 2cm square of rubber, drilled a 6 mm hole in it, put a bit of all-purpose cement on the bottom "jaw", put the rubber on, and tightened the top nut.  After a few hours to let the cement dry I trimmed it to the circle with a craft ("Exacto") knife.
Much nicer now: the board doesn't walk around when you clamp down on it.
