After playing with it for a while, the temporary design ended up pretty worthless. The string comes out just the same if it's pulled towards the opening. It might as well be a single piece if they're not welded & 2 pieces only if they're welded.
A few more permanent pieces got painstakingly sized for clothing. The newest cords are taking a 3.5 ID & .75 opening. Started building up a collection of used pieces for speeding up the size tests.
Some clothing is down to being worn only 1 more time.
Chafing was a problem with the welding. This led to a new death star design. The welds went inside grooves.
The flat design might still be useful when there's no danger of chafing. It's harder to assemble the death stars.
lion mclionhead
