Another Base + Electronics Box
A project log for Light-Painting Robot
A 3 DOF robot capable of light-painting on a plane
katieKatie 03/30/2025 at 01:160 Comments
Electronics Update:
I designed and printed a new box for the electronics. It was made of two 3d-printed halves, which I plastic-welded together. I then added some Bondo and spray paint to make the box look cohesive. I also added some connectors to easily detach the electronics from the robot arm.
Base Update:
I mounted the robot to a 3/4" piece of MDF. I added some 1/2" bolts on the corners to prop the piece up and make room for the mounting screw heads/ends.
