IMU communicating with Uno
A project log for Self-Righting Unicycle
A robot that balances on a single rolling wheel by using a reaction wheel to counteract tilting and to spin up from rest
caitlyn-colomaCaitlyn Coloma 02/14/2025 at 00:210 Comments
We successfully connected the BNO085 IMU sensor to the Arduino Uno over I2C.
Minimal RAM on the Uno means we couldn't use Adafruit's BNO08x library. Luckily Sparkfun's BNO085 library works just fine. We were able to get real-time readings of rotation vector data with some built-in example sketches.
Once we mount the BNO085 to the unicycle body, we can continue calibrating for the upright position. TBD if control of two IMUs oriented on each wheel's axis of rotation is necessary/plausible.
