Rimu is a modular electronic product designed to solve various problems through a series of interchangeable modules. We have recently launched our new PWM switching module and will continue to introduce more functional modules in the future to meet evolving needs.
Rimu’s unique magnetic adsorption design makes connecting modules to the host simple and quick. With just a gentle snap, you can quickly connect, eliminating the need for complicated operations. Each module is equipped with a dedicated interface to ensure precise functional alignment and seamless compatibility with the host, providing users with a more intuitive and convenient experience.
Rimu PWM Switch Module
The Rimu PWM switching module offers excellent compatibility, supporting both 5V and 24V voltages, making it suitable for a wide range of electronic projects. It not only enables precise dimming of LED lights (Single-color LED, Dual-color LED, RGB Stripe LED,RGBWY LED,Motor) but also drives motors and other inductive loads, offering greater design possibilities.
Single-color LED
Single-color LEDs are the most basic and widely used light sources, commonly found in decorative lighting and task lighting applications. With the Rimu PWM switch module, you can easily adjust the brightness and switch colors for up to five independent single-color LED strips.
Dual-color LED
The Rimu PWM switching module offers greater flexibility for dual-color LEDs. Beyond the common white and yellow, you can combine any two colors and achieve neutral white light with various color temperatures through precise dimming, meeting the needs of different scenarios.
RGB Stripe LED
With Rimu PWM switching module, you can unleash the full potential of your RGB LED strip. By precisely adjusting the brightness and color of red, green, and blue, you can easily create your own unique lighting effects to suit any mood or occasion.
RGBWY LED
RGBWY LEDs on the market are mainly divided into two types: RGBW LEDs and RGBY LEDs. Rimu combines the advantages of both, allowing independent control of brightness and color adjustment for five LED strips, effortlessly meeting diverse creative lighting needs.
Motor
Motors are essential driving devices in industrial production and daily life. With the RIMU PWM switch module, up to five inductive loads, such as motors and electromagnets, can be independently controlled for start, stop, and speed adjustment, easily meeting diverse application needs.
Long — Term Support
RIMU is a modular IoT control device set to launch on Kickstarter in March 2025. We’ve established a dedicated forum where you can share insights, offer suggestions, and engage with other enthusiasts. Every idea you contribute could be the key to making RIMU even better!
If you’d like to learn more about RIMUand stay updated on its progress, feel free to visit our official website. You can also explore our previous articles to gain a deeper understanding of RIMU. We sincerely invite you to support us on Kickstarter and join us in witnessing RIMU’s transformation from concept to maturity. Let’s create an even better RIMU together!
Dengtec
Wishmaster
pieslorde
ginko.garfield
