Pressure Regulator Research
A project log for Iron Man CO2 Repulsor
Hand repulsor strong enough to break a pane of glass using CO2 or compressed air, a high pressure regulator, a solenoid valve, and Arduino.
pete-vieiraPete Vieira 01/23/2025 at 20:540 Comments
Specs
Options
  1. Paintball gun regulators
    1. Inlet pressure gauge is 1000 - 4500 PSI
    2. Ohh! The gauge is only inlet, so it not actually a regulator! Some do allow outlet adjustement.
    3. Very small
    4. Unknown flow coefficients
    5. Unknown outlet pressure
    6. Not too expensive
    7. Options
      1. Polarstar Micro MR Gen2 Regulator (1)
        1. Max inlet pressure: 1500 psi
        2. Regulated outlet pressure: 20-200 psi
        3. Input thread: G 1/2-14
      2. Vavoger Paintball PCP Airsoft Co2 Tank Cylinder Regulator Adapter DIY Kit (adjustable-range: 0-200psi)
      3. Preece Precision Series 3000 High Flow Adjustable CO2 Regulator 0-250 psi
        1. Designed for CO2
        2. 45 Cubic Feet per Minute (CFM)
        3. Regulated outlet pressure: 0-250 psi
        4. Inlet connection: CGA320
        5. Unknowns: Where to attach gauge
  2. Industrial regulators
    1. More expensive
