Removing the Paint
A project log for the seraphia tinka–
the story of my first hybrid steelpan prototype that kicked off my instrument building journey
seraphia-scarlettseraphia scarlett 9 hours ago0 Comments
I used the following day to burn the blue coating and shave the surface clean using an angle grinder. You can also see a few stronger dents in the metal where I planted a few hits powered by the frustration of the rubber mallet no longer being of service to my sore, over-worked arms and wrists.
