Wiring Diagram so far! It looks like the enable pin allows us to cut power to the driver, so we won't need a relay. Note that the driver we're using is actually the DM542--this is just what was available in Fritzing. Additionally, since the only reason we have a breadboard is to ground everything, we may look at alternative ways to connect those wires.
