The mounting system for the main components (gear, stepper motor, limit switch) has been designed for 3d printing. The current plan is to use zipties to fix the motor, and hot glue to fix the limit switch. The plate will be attached to the wall with command velcro strips.
The motor driver, Arduino, and possibly the breadboard all still need to be mounted.
Lark
