Thought I'd add this into the mix, it's about 65% including 5 Macro keys on the left.
I removed key that are not used or more precisely, not required for normal day to day work.
The four on the right side are: Home, End, Print Screen and Insert, I never use the rest, beside if necessary I can always add missing keys to macros on layer 3 or 4...
Inspired by my Akko/Monsgeek M1W (which is available with VIA support, my version didn't, I bought the wrong version but I love it. Come to think on it, I could make an exact layout as my M1W and swap the boards... more work... ;)
Front: Keys and stabilizers
Back, component side... (connector should be on back of board)...
Michael O'Toole
