Just noticed, the Caps Lock Led is in the wrong place, so it requires a simple hack (don't waste five prototype boards). A very simple mistake, easily fixed... must do better ;)
Also need to move the drill hole for it on the keyboard plate...
A project log for Basic Hot-Swappable Keyboard with RGB
Designed for hand assembly and low cost. Can be powered from an STM32, RP2040, or any module with enough GPIOs.
