EEG Mini
A Compact Bio-Signal Acquisition Board
This project is a redesign of OpenBCI's Ganglion board, maintaining the same analog front-end but incorporating modifications for a smaller form factor. While some components are still pending delivery, the project aims to implement a flex sensor interface for the electrode section, primarily focusing on EMG and EEG applications.
right now i won't be uploading the design files i think the current version needs some improvements and will provide design files of the following versions
  • changing to single board integration
    Aditya56h • 07/17/2025 at 19:46 • 0 comments
    The first revision of the boards worked well (there was an issue with the analog frontend PCB). I have designed and populated a new PCB with STM32WB55MMG module and a battery charging module included with the MCP3912 frontend as a single PCB. I think this idea of a singular PCB is better than the stacking version of the project. Right now the PCB size is a bit big (I want to test all functionalities). The battery charger part works and I am able to program the STM32WB55 module using DFU mode via USB-C for now. I have some components left to arrive. I will then continue to develop the firmware for this board and then work on final version of this project. I have placed a limit of 35x35 mm board size limit for that revision. In my previous design I realized I didn't need all the channels from MCP3912, so now I am using half the channels. Interconnecting mezzanine connectors had tendency to rip the traces (I pulled the boards apart too hard).
View project log
