To build a Magnetostrictive sensor rig you do not need much. A wire clamp and eventually a wire tensioner, a coil and a moving magnet are enough. Of course you need the electronics described above. Here as damper a wine cork is used.
Coil, magnet holder and tensioner can be found here: Parts for Basic Magnetostrictive Position Sensor
Florian B.
