Testing the first board
A project log for M.2 A-E Key Simple Carrier Board
A carrier to connect a M.2 Board to USB breaking out all other signals to TH testpoints
magicwolfiMagicWolfi 01/30/2025 at 02:060 Comments
Testing the board went well so far.
- 3.3V switcher is working and stable at 3.259 V.
- Power switch is working.  0V when the jumper is open.
- Got USB connection on the 2nd try. Issue was the standard USB-C issue: I did not notice that I used a power only cable because of no markings on the cable. With a good USB-C data cable I got immediate connection to my M.2 RP2040 board. It showed up as the regular RP2 device and I could program my test FW without issues.
- Power rail LEDs are working.
- 1.8 V regulator is not populated yet.
- And we can play the usual game of rev1 to find the uups in the silkscreen. This time it is 2 of them.
Rich text editor
