Say Loudly: Dispense Towel
Voice-activated paper towel dispenser
Wall-mounted paper towel dispenser that dispenses towels on hearing the verbal command, "dispense towel".
Made by It's a Feature:
3megabytesofhotRAM: https://3megabytesofhotram.github.io/blog/
BrainHu42: https://github.com/BrainHu42
Nika Chuzhoy: https://github.com/nika-chuzhoy/
We're also the team behind Audiomatic, an app for automated video dubbed translation: https://www.audiomatic.app/
DISPENSE TOWEL!
Motor Holder (NEW).stl
New motor holder design https://www.tinkercad.com/things/hq1rzpcs7i1-motor-holder
Standard Tesselated Geometry - 11.51 kB - 03/15/2025 at 20:04
Download
Scott Paper Towel Dispenser Pulleys.stl
Pulleys for moving towel dispenser https://www.tinkercad.com/things/feDYdL5Cbvt-scott-paper-towel-dispenser-pulleys https://cad.onshape.com/documents/380de83321b66506218ea3fa/w/c4c5e723950741839b369f04/e/5c50764f8d3d2605ba21e744
Standard Tesselated Geometry - 339.44 kB - 03/08/2025 at 21:02
Download
Motor Holder.stl
Old motor holder design (changed because it was less stable and the motor moved around too much)
Standard Tesselated Geometry - 10.24 kB - 03/08/2025 at 21:02
Download
Grey Core Paper Towel Adapter.stl
Blue core dispenser / grey core towel roll adapter piece https://www.tinkercad.com/things/egoK4DOFNax-scott-bluegrey-core-paper-towel-adapter
Standard Tesselated Geometry - 6.92 kB - 03/08/2025 at 21:02
Download
  • 1 × Scott® Pro™ Manual Hard Roll Towel Dispenser
  • 1 × DC motor 12V 10 RPM
  • 1 × DC motor driver module (at least 1A)
  • 1 × Raspberry Pi 4 2GB
  • 1 × Microphone
View all 9 components
View all 8 project logs
  • 1
    Implement wake word detection
    SSH into your Raspberry Pi and load the "Dispense Towel" detection code at https://github.com/BrainHu42/spencer-the-dispenser. Attach your microphone to the Raspberry Pi and test that the wake word is being detected.
  • 2
    Add motor controls
    Using your driver module, link the motor controls to the Raspberry Pi's wake word detection output. The wake word should now trigger motor rotation.
  • 3
    Mount motor and pulley system
    Open your paper towel dispenser body. On the side of the dispenser axis opposite to the manual control handle, there is a nub that should fit the indent of the smaller pulley should fit perfectly. You will need to remove some springs. Refer to logs for pictures.
    Finally, mount the motor in the motor holder, the larger pulley on the motor, and the belt between the pulleys. Refer to logs for pictures. (We don't have a picture of the new motor mount).
View all 5 instructions
Rich text editor
