Small adjustments
A project log for AEFC - Ambient Energy Field Converter
A system designed to capture and collect energy from EMFs, now being refined to enhance circuit efficiency and output.
rhea-raeRhea Rae 11/15/2025 at 15:190 Comments
The AEFC Super Cap Bank is currently at 8.02Vdc out of a total 16Vdc 0.25 Farad capacitance. The Harvest Capacitor is at 8.04 Vdc currently 2200uF.  On coil 3 I placed 10pF capacitors across the three of the four rectifier diodes in the coil.  I am thinking of Putting one across the last rectifier diode in that coil circuit. Coil 3 coil setup is far different than coil 1 and 2 and is completely Positive Biased. I'm curious as to how it would or wouldn't react if I took it to the top of a really high mountain?  There is currently a 1.1 - 1.2Vac voltage reading between coil 1 and 2 as well as 1.5 Vac voltage reading between coil 1 and coil 3.
-RR
