We have the Jetson Nano up and running and have trained it with our facial recognition model. We have also built the relay circuit to power the solenoid and 3d printed a casing to hold the solenoid to the door. Our next steps will be to connect the solenoid to the Jetson to be controlled from there rather than the Raspberry Pi Pico that we used to test and build our relay circuit. After that, we will work on connecting everything to the door. We will also need to 3d print another piece to attach to the end of the solenoid at this point to actually push the lock on the door.
Henry
