Finally got some Cuda Demo code to link. Hopefully, it will also be running soon. Of course, there is also that fact that I have all of my own real hair, for the most part - that is even after much proverbial hair pulling and head bashing. Yeah, apparently a certain amount of masochism or else capacity for mental self-flagellation is pretty much a requirement for any would-be software engineer when it comes to certain things, such as project and linker settings in Visual Studio, of course! What else did you think that I might be talking about?
So, after spending a hopefully not too unreasonable amount of time searching other forums for "why won't my MFC project link against CUDA", and finding that the debug dumps are numerous, long, and generally incomprehensible - on pretty much every forum, where the advice is almost a universal "Good Luck with That!" - well you get the idea. So, I knew it was time to jump right in and swim with the other angry crocodiles while contemplating how many other ways there might be to somehow end up mopping the floor with my own blood - hopefully, only in a virtual sense, of course.
If you don't understand the need for such graphic language regarding this subject, then you haven't been doing this for very long. Speaking of graphics? Here is proof that I can make calls into legacy console applications, from MFC no less, return to MFC, and then run a test that lets me call some code in a cuda_kernel.cu file, which in turn makes callbacks into my very own favorite PASCAL-style IO routines. YES!
First, we run the MFC application, and from a Windows menu we launch a console and then run an interactive number base conversion routine which is actually in a "Console Applications" library then upon returning to MFC we make another menu-driven call into some stuff in the "Cuda Runtime" library which then makes calls back into VS2022 generated code in the Frame Lisp library - which is where the PASCAL-style IO intrinsics are located.
Getting CUDA compiler-generated code to link was not all that hard, once I got this mess to compile that is. Now it's time to try running some actual CUDA code of course, and then we can do some other long overdue stuff, like trying to figure out how Deep Seek works, and so on.
Of course, we can't be kept waiting. Now, can we?
Now adding vectors in parallel CUDA style. Watch out Atari Genetics, and/or Number Base Conversion - hopefully you might be next!
glgorman
