I had some small plastic storage boxes lying around and needed a way to deliver LED light to a watch. So I took the lid off one of the storage containers. The bottom conveniently is shaped a bit like a lense so there wasn't a lot of distortion interferring with the light from the LED spot. Then all I needed was some clear adhesive film to attach the spot to the outside of the container and then freehand cut a strip of paper to form a reflective layer inside of the container.
Total cost: less than 5€ for 20K+ Lux of energy with 0.7W input. The spot has a convenient female USB-A plug to use basically everywhere.
Suits my needs perfectly.
