Updates
A project log for ArduinoKermit48
A minimal port of the Kermit protocol to Arduino allowing transfer of objects from HP48 series calculators
eugeneeugene • 02/11/2025 at 00:14•0 Comments
I made a bunch of updates. Been working on replacing my proof of concept code with more of the Kermit projects e-kermit code. I'd had to comment out a lot due to lack of resources o the Arduino.
I'm using the decode function from e-kermit now, just modified it a little to use a small fixed file buffer instead of their multiple buffers. Using all of their kermit struct now but added in my file buffer and a the optional fields that HP uses but e-kermit has hard coded.
