Post-apocalyptic cyberdeck
This hand-built cyberdeck is designed as a durable, compact and fully functional mobile system inspired by post-apocalyptic aesthetics.
💾 The heart of the cyberdeck is the Raspberry Pi 4 Model B (4GB), supplemented with a 256GB SSD. Power is provided by three 10Ah Li-Pol batteries.
🖥 The main control is via a 7" IPS touch screen, a built-in compact keyboard and a clear control panel.
⚡ The cyberdeck is equipped with a number of inputs and outputs for expansion, including sockets for a regulated power supply and a universal I/O port with support for I2C, 1-Wire and other interfaces.
📊 Voltage, current and temperature monitoring is provided by an Arduino connected to a TFT display, which also controls the fans for optimal cooling.
🚀 The goal is to create a highly durable and functional device that can handle extreme conditions and allow work even in the field. The design and wiring are adjusted as you go, but the basic concept is clear - an indestructible cyberdeck with long durability and wide connection options.
  • 1 × Arduino mega
  • 1 × Raspberry Pi 4 4GB main CPU
  • 1 × AXAGON EEM2-SA, M.2 SATA screwless RIBBED box, SuperSpeed USB 5 Gbps
  • 1 × Verbatim VI560 S3 256GB SSD 256GB
  • 1 × TFT LCD 4" 480x320, SPI LCD for Arduino
View all 9 components
