HP1142A to 1143 probe power supply
Add HP 1143A functionality to HP1142A probe power supply
0 followers
Some HP/Agilent probes such as HP54701A are not compatible with the old HP1142A power supply. Instead the 9 pin DIN connector they are using 7 pin Lemo, and there are slight difference how the offset is implemented.
Unlike HP1142A the HP1143A is hard to find and when found the price tag is usually way to high, all units i found are above $600.
This project is add-on to the HP1142A power supply adding the HP1143 functionality.
This project is add-on to the HP1142A power supply adding the HP1143 functionality. The main difference between both units are :
- HP1142A provide +/-15 and +/- 6 V when HP1143A provide +/- 17.3 V
- HP1142A offset is voltage based, where the HP1143A offset is current based +/- 5 mA
- HP1142A has separate signal and power grounds and in HP1143A we have only one
The PCB fit over the existing HP1142 PCB seating on 4 spacers. Attached photos showing where are the 5 connection to the HP1142A board.
The board on the photos is my first version. Here i am uploading revision 2, where i add a differential amplifier to deal with the potential difference between analog and power ground in the HP1142 and also add a trimer allowing the HP1143 offset to be set to 0 independently.
The HP1142A rectifier provide +/- 32 V, and voltage drop on the LM3x7 is significant. With the current design the temperature on the chip is around 70 C far from the max specified 125 but adding a small heatsink may be beneficial.
HP1142-1143 CAM.rar
RAR Archive - 5.18 MB - 02/14/2025 at 03:55
Download
HP1142-1143 CAD.rar
RAR Archive - 1.14 MB - 02/14/2025 at 03:55
Download
HP1142-1143 Gerbers.zip
x-zip-compressed - 100.96 kB - 02/14/2025 at 03:55
Download
1141AUSerService.pdf
Adobe Portable Document Format - 10.10 MB - 02/14/2025 at 01:36
Preview
Alltest-HP-Agilent-Keysight-1143A-Manual.pdf
Adobe Portable Document Format - 1.64 MB - 02/14/2025 at 01:34
Preview
View all 8 files
View project log
