A 400 LOC in C Dialog Box using only Xlib (X11).
Something Like Zenity.
X11Dialog.hX11 Dialog header filex-chdr - 11.86 kB - 02/16/2025 at 08:35 |
Xlib.pdfXlib ReferenceAdobe Portable Document Format - 349.55 kB - 02/16/2025 at 08:35 |
ClarkY.csvDemo Input FileComma-Separated Values - 3.82 kB - 02/16/2025 at 08:35 |
csv2dxf.cDemo Main Programx-csrc - 10.07 kB - 02/16/2025 at 08:35 |
csv2dxf.runDemo executablerun - 38.88 kB - 02/16/2025 at 08:35 |
Buttons GUI
I am going to take one of my programs (csv2dxf.c) and replace Zenity with my Dialog.h header file.
Lets call my GUI "Buttons", as it is conceptually a grid of buttons but with differing properties. The main constraint is that the grid is fixed width and fixed height.
So the following image is a two column by ten row grid. Each cell is 160 pixels wide by 50 pixels high.
Obviously I can merge cells such as the title and sub-titles.
Here is how the grid is defined:
// Here is our basic cell grid defintions --------------------
#define cellWidth 160
#define cellHeight 50
#define cellColCnt 2
#define cellRowCnt 10
#define cellCnt 20
Cells
Cells are defined by a structure:
// The master cell structure ---------------------------------
enum modes {hidden,label,input,cancel,okay,toggle,button};
struct CELL {
int Id;
int Forward;
enum modes Mode;
int Width;
int Height;
int PosX;
int PosY;
bool Selected;
int ButtonClr;
int PaddingWidth;
int PaddingClr;
int SideWidth;
int SideLightClr;
int SideDarkClr;
int FontSize;
char FontName[64];
char Label[32];
} cells[cellCnt];
Note button types or modes are defined in the enum structure.
Button Style and Colours
The defaults for every cells are:
// Default cell properties ----------------------------------- #define cellMode hidden #define cellSelected false #define cellButtonClr (160)*65793 #define cellPaddingWidth 5 #define cellPaddingClr (256-32/2)*65793 #define cellSideWidth 5 #define cellSideLightClr (160+64)*65793 #define cellSideDarkClr (160-32)*65793 #define cellFontSize 15 #define cellFontName fontName9x15 #define cellLabel "Label"
I have used a grey for my buttons but it is configurable.
Fonts
Fonts are based on what is available under the X11 system. There are 948 fonts on my system but I only bound 18 fonts named in the font alias file. The font alias file is for backward compatibility. The aliases map to real font names.
For example:
"variable"
maps to
" -*-helvetica-bold-r-normal-*-*-120-*-*-*-*-iso8859-1"
which maps to
"-adobe-helvetica-bold-r-normal--0-0-0-0-p-0-iso8859-1"
which maps to
"-urw-nimbus sans l-bold-r-normal--0-0-0-0-p-0-iso8859-1"
Not all fonts work, but those with character set "iso8859-1" appears to be good.
One problem is that the X11 system uses bit maps and therefore don't re-scale well.
const char *fontNameFixed = "fixed"; // Same as 6x13
const char *fontNameVariable = "variable";// Helvetica Bold 13
const char *fontName5x7 = "5x7";
const char *fontName5x8 = "5x8";
const char *fontName6x9 = "6x9";
const char *fontName6x10 = "6x10";
const char *fontName6x12 = "6x12";
const char *fontName6x13 = "6x13";
const char *fontName6x13bold = "6x13bold";
const char *fontName7x14 = "7x14";
const char *fontName7x14bold = "7x14bold";
const char *fontName8x13 = "8x13";
const char *fontName8x13bold = "8x13bold";
const char *fontName8x16 = "8x16";
const char *fontName9x15 = "9x15"; // Nice fixed default
const char *fontName9x15bold = "9x15bold";
const char *fontName10x20 = "10x20"; // Good Sub-tile
const char *fontName12x24 = "12*24"; // Good title
Layout
Best to draw a grid for your GUI numbering the cells from 0 to cellCnt-1 by column and then row:
| Cell 0: Title | Cell 1: Title continued |
| Cell 2: Sub-title | Cell 3: Sub-title continued |
| Cell 4: Label | Cell 5: Input |
| Cell 6: Label | Cell 7: Input |
| Cell 8: Sub-title | Cell 9: Sub-title continued |
| Cell 10: Label | Cell 11: Input |
| Cell 12: Label | Cell 13: Input |
| Cell 14: Label | Cell 15: Input |
| Cell 16: Label | Cell 17: Input |
| Cell 18: Cancel | Cell 19: Okay |
Overwrite the button defaults as required.
Here is the first row:
// Row 1: Title
cells[0].Mode=label
strcpy(cells[0].Label," CSV to DXF");
strcpy(cells[0].FontName,fontName12x24);
cells[0].FontSize=24;
cells[0].Width=2*cellWidth;
cells[1].Mode=hidden;
