Background/Inspiration
Making a cyanotype print had been on my list of projects for a while. I was given the idea by the likes of Mathieu Stern and Nile Red. You only really need three things to make a cyanotype: a sensitized medium (usually paper), a negative of what you want to image, and a source of UV light. The UV light converts the chemicals into prussian blue pigment and the negative selectively exposes the medium to create the image. Old school blue prints and so called “sun prints” use a similar process. I am not going to dive into the chemistry here because I don’t really understand it. ¯\(ツ)/¯
Typical Process
Typically custom negatives are made by printing a black toner onto a transparency sheet and this is the approach I initially tried to take. This should have been doable, but I was struggling to get this to work without smearing.
In the midst of this struggle, hands stained black with toner, I started working on the other side of the problem, the UV light. I could have tried the sun, but the sun is rather variable. I could have bought a UV lamp online, but I am a h̶o̶a̶r̶d̶e̶r̶ hacker at heart, so I looked around to see what I had in my workspace. I had an old (what I believed to be functional) Phrozen Sonic Mini resin printer collecting dust in my closest that has a nice bright array of UV LEDs inside.
That is when it hit me, what is a resin printer but a source of light with a programmable negative? Screw trying to print a transparency, we are going digital!
First Pass
My first pass at convincing my 3D printer to print a 2D image involved writing a python script to make an OpenSCAD program that would generate a STL from a TIF image where each pixel is converted into a rectangular prism whose height corresponds to the greyscale value of the pixel. This was horrible to run and I had to tweak the settings in the nightly version of OpenSCAD to get it to run at all. But eventually I had my STL of Inigo.
from PIL import Image
from pathlib import Path
import PIL.ImageOps
im = Image.open("inigo-montoya_01.png").convert()
invert = PIL.ImageOps.invert(im)
PIXEL_SIZE = 0.063
WIDTH = invert.width
HEIGHT = invert.height
with open("myfile.scad","w") as file:
file.write("pixels = [")
for i in range(WIDTH):
for j in range(HEIGHT):
file.write("["+str(i*PIXEL_SIZE)+ ", " + str(j*PIXEL_SIZE)+ ", " + str((invert.getpixel((i,j)))*0.001) + "],")
file.write("];\n")
file.write("for (pixel = pixels){\n")
file.write(" translate([pixel[0],pixel[1], 0])\n")
file.write(" linear_extrude(height = pixel[2])\n")
file.write(" square([{size},{size}], center = false);}}\n".format(size = PIXEL_SIZE))
After generating the STL, I still had to scale and slice the file. I set the layer speed targeting about a ~10 minute total exposure time based gut feeling. I went to upload the file to my printer and to my surprise, the screen had stopped working. Even worse, I was hoping to submit my application to be an OpenSauce Exhibitor and the application was due that day. I submitted what I had, and fortunately they were generous enough to let me update them if I got it working in the next week or two, and they would reconsider my application. Now I just had to prove that it worked.
I rushed over to my friends apartment who had a much nicer printer and convinced him to let me place some paper on the build platform and give it a shot. To my surprise, my first attempt worked! It was tiny and inverted, but the image was totally there! As far as I know, this was the first ever cyanotype made with a 3D printer.
With a few tweaks I managed to fix the size and inversion issue and got a nice looking image.
I sent my results off to the staff at OpenSauce and to my surprise, I was accepted!
Optimizing the Process
Now that I proved that this was possible, I needed to optimize the process if I wanted to go to OpenSauce. Just having a few prints would be rather boring in an exciting and loud place. My goal was to be able to run a cyanotype photo booth. Due to the nature of the chemistry and the intensity of the light in the printer, I was not going to be able to get exposure times under 15 minutes, so if I wanted to make prints in a reasonable time, I was going to have to do smaller wallet sized prints grouped together. Even with grouping the photos, the process of converting the image to an STL, slicing that STL, then uploading it to the printer added another 10 or so minutes and was quite manual. I needed something better if I was going to be taking photos, making prints, while also talking to hundreds of people about this project.
I started researching how resin printers work under the hood. Unlike FDM printers which run off g-code commands, resin printers don't do much more than display a monochrome slideshow while moving a stepper motor. My printer natively runs off .goo files which Elegoo open sourced, but writing my own software to write those files seemed a little out of scope. Luckily I found an awesome piece of software called UVtools that allows for resin printer file manipulation and conversion between file formats through a GUI or the command-line, score! Thanks sn4k3! This allowed me to take a zip file of images and JSON file withe the print settings, and convert it to a .goo file by calling the program from a python script.
To get the images for each "layer", it was fairly trivial to save out a series of binary images, where pixels were on if the brightness of that pixel in the original images was above an ever increasing threshold. I chose 255 layers to give me roughly 8-bit color depth. There were a few other hiccups and quality of life problems that I had to solve, including the pixels of the printer not being square, auto cropping and down scaling, converting a series of images into a grid of smaller images to make batching photos easier, etc. After a few hours of coding, I had a workflow that (I hoped) would not be too terrible to run at OpenSauce.
Getting Lost in the Sauce
~Under Construction~
Whats Next
- Make a GUI for the program so that it is easier to use and make it adaptable to a wide range of printers
- Determine actual resolution of image
- Calculate exposure curve and accommodate for it in the output images
- Try alternate photochemistries (anthotypes, inkodye, chlorophyll prints, lumen printing, potato, etc.)
- Paper coating machine
