Rimer app V0.62 released.
SIO tuned up - speed setting added, power control unified with DIOs' function
Basic-D updated - variable type is now set by dot and the modifiers var.b, var.w, and var.i for byte, word and integer variables.
BAS interface "load", "run", and "list" commands were updated: "load" can now run the program when called with a line number after the file name. "run" now supports starting line number, and "list" can be performed from a certain line and listed lines can be limited.
Sergey
