30.03.2025
I continue to work on the circuit and design of the microwave indicator.
I have made a PCB layout, and have completed it by about three quarters. At the same time, it became COMPLETELY clear that the device can be placed on a single board, in acceptable dimensions.
Without such a long and tedious procedure as tracing, it was impossible to be sure of this. I drew a single-board circuit.
I modeled individual units in LTSpice, for example, the input amplifier.
At the same time, it must be admitted that for complete confidence it is necessary to make a layout.
