I've just finished uploading (to printables) and testing a Z stage adapter that works with the existing linear stage to turn it into a precision Z stage. I was originally working with a scissor lift based design but could never achieve the desired accuracy. I may one day release that design but its just too flimsy for my linking in its current state. As a part of this I've gone back into the Original Linear stage design and modified the adjuster so the top of the stage can move over the handle more easily. This design will also work with the upcoming motorized stage that I'll release along side a neat control PCB Shield for the Pi Pico to make using it easier for non-electronics people. There are also some neat 90 degree adapters for the stage mounting system included in this update also on my printables and in the easy stage collection I've linked below:
