One PCB, Many Uses: The Power of Solder Bridges
By adding or removing a few key components and shorting specific solder jumpers, the same board can function in six different modes:
(💡 Short = connect with solder)
1️⃣ Standard Relay Mode (The Original Design)
✔ Install: J1 (screw terminal) and K1 (relay)
❌ Remove: J2 (fan header) and R3 (10K pull-up resistor)
⚙ Behavior: The board switches a relay via USB commands.
2️⃣ Solid-State Relay (SSR) Mode
✔ Short: B6
✔ Install: J1 (screw terminal, now outputting 5V for SSR)
❌ Remove: J2 and R3
⚙ Behavior: Similar to option 1, but the relay provides a switched 5V between Pin 2 and GND.
3️⃣ Simple Fan Control (2- or 3-Pin Fan)
✔ Install: J2 (fan header)
✔ Short: B4
❌ Remove: J1, K1, and R3
⚙ Behavior: The board powers a 2- or 3-pin fan with PWM speed control applied to the power pin.
4️⃣ PWM Fan Control (4-Pin Fan)
✔ Short: B5
✔ Install: J2 (fan header) and R3 (10K resistor in relay coil holes)
❌ Remove: J1 and K1
⚙ Behavior: Speed control by PWM on Pin 4 (PWM input).
5️⃣ Servo Motor Control
✔ Short: B5 & B1
✔ Install: J2 (wired as a servo header)
⚙ Behavior: TIM2 generates servo control PWM (50Hz, 1-2ms pulse width).
6️⃣ UART Communication Interface
✔ Short: B2 & B3
✔ Install: J1 (now a UART terminal block)
❌ Remove: J2 & K1
⚙ Behavior: J1 now provides TX/RX pins for serial communication.
Ditching the Crystal: How USB Syncs Itself
Most USB-enabled microcontrollers require a crystal (typically 12MHz) for accurate timing.
But here’s the cool part: The STM32F042K6U6 doesn’t need one. It can self-synchronize using its internal RC oscillator.
How USB Self-Synchronization Works
🔹 USB Full-Speed mode (12Mbps): The host sends a Start Of Frame (SOF) pulse every 1ms.
🔹 The STM32 uses these pulses to fine-tune its internal oscillator.
🔹 This eliminates the need for an external crystal, reducing component count without losing accuracy.
That means fewer parts, lower cost, and easier assembly.
The Magic Button: One Switch, Two Tricks
One of my favorite design choices was a dual-purpose tactile switch connected to the BOOT0 pin.
Feature 1: Enter Bootloader Mode (Firmware Update)
Hold the button while plugging in USB → The STM32 enters bootloader mode.
Now you can flash firmware over USB, no programmer needed!
Feature 2: Manual Override (Toggle Outputs)
When the STM32 is already running firmware, pressing the button toggles the relay or fan manually—without USB commands.
💡 BOOT0 is repurposed as a general-purpose input once firmware is running.
USB Command Interface
The firmware uses USB CDC (Virtual COM Port) to communicate via serial commands; accepts structured ASCII commands (easy to use in Bash, Shell and Serial Terminal).
Example Commands (Send via Terminal/Script)
| Command | Function |
#S1!
| Switch ON relay |
#P3!
| Pulse relay for 300ms |
#F90!
| Fan at 90% PWM |
#W40!
| Load controlled with a PWM signal at 40% (B4 or B5 Closed) |
#A75!
| Servo motor positioned at 0° |
#Z15000!
| Set the PWM frequency at 15 KHz |
#I!
| Transmit on the USB the input pin state |
#T!
| Transmit on the USB the fan RPM |
#O!
| Transmit on the USB the PWM percentage of the output |
How to use on Linux Systems in Bash
// To send a command
echo '#S1!' > /dev/serial/by-id/usb-IT_Logic_USB_Relay-if00
// To read a result and store in a variable FAN_TACH:
echo '#T!' > /dev/serial/by-id/usb-IT_Logic_USB_Relay-if00
read -d'~' -t1 FAN_TACH < /dev/serial/by-id/usb-IT_Logic_USB_Relay-if00
echo $FAN_TACH
How to use on Mac Os in Bash
echo '#S1!' > /dev/cu.usbmodem8301
alcor6502
ajlitt
ESP32andmore
Martin W. Kirst
Thanks for your comment. It will be useful!
