Final Transmitter Setup
With the transmitter situation figured out, I moved onto pairing the X8R receiver without issue.
I configured throttle/steering inputs and mixes on the transmitter, and set the servo inputs in Ardurover.
M80 GPS Module generating 3D fix.
ESC min/max/reverse calibrated - Transmitter calibrated in mission planner.
Assembled prototype body, fixed ESC in front portion. Printed FC mounting board for quick access on the top. Includes 4 vertical holes for carbon fiber antenna trees. Mounting receiver and GPS high on the vehicle for initial range testing.
Next Steps:
Receive/Configure MAVlink radios
Test VL53L0X ToF sensors - test multiplexing
Autonomous waypoint mission test
Waypoint updates mid-mission testing
Obstacle avoidance
Powertrain range testing (2200 MaH, 5k MaH, 10k MaH
