Rd-60
- Package: SMD-24, can be surface-mounted or through-hole
- Pin spacing: 1.27mm
- Size: 18.5x22.5mm
- Supports serial port output
- High-precision detection (minimum threshold 8.3cm)
- Supports FFT display
- Supports point cloud data display
- 16 available IOs
- Supports secondary development
- Supports low power consumption (28uA)
- Provides test host software, click to view effects
- Supports serial port Shell command control
Rd-61
- Package: SMD-8, can be surface-mounted or through-hole
- Size: 6.5x18.5mm
- 3 available IOs
- Supports low power consumption detection (28uA)
Rd-60-Kit
- Supports Rd-60 module interface
- Supports Rd-61 module interface
- Dual TTL interfaces, supporting both command sending and data output
- Supports low power consumption testing
- Can be connected to a host computer for data monitoring
- Supports up to 2M bps baud rate
- All available interfaces are brought out
