3D Modeling and Mechanical Design PART IV : The curved rail & Limit switches
A project log for MatAir - A Robotic Spherical Chessboard
A spherical chessboard where a robotic arm plays moves from an online game.
nasserNasser 03/25/2025 at 15:390 Comments
CURVED RAIL
The next major component we tackled was the curved rail.
Due to its large size and the need for durability, we chose to laser-cut it from plywood/acrylic instead of 3D printing it.
Dimensions:
The rail is composed of four layers, all secured together with M5 screws:
  1. Two outer planks — 5 mm thickness each
  2. Inner plank — 10 mm thick, this is the guide surface where the cart wheels will slide
  3. External gear layer — 5 mm thick, this gear will be driven by the cart to move along the curve
    • The design of this driving system is inspired by this mechanism:
Rail Support: Feet and Top Part
To hold the rail we designed those two piece :
Rail feet
The rail "Feet" is a very important part, it house the chessboard stepper motor, the cart and the orb limit switch.
It connects to the rail using a m8 bolt
Limit switch
As we're using stepper motors to move the cart and chessboard, we should be able to achieve a high degree of accuracy when moving to a position, but one problem with stepper motors is that, being an open-loop system, they wouldn't know, for example, where they are at start-up.
To solve this problem, we used limit switches in the path of each motor so that they could have a base (reference) position.
Here's the limit switch for the chessboard and the cart :
CHESSBOARD
A 3D printed piece is fixed to the stepper shaft.
CART
Rail Top
The Top part help to complete the assembly
It also connects to the rail using a m8 bolt
Here is the final assembly showing the curved rail, feet and top parts, stepper motor, the spherical chessboard, and the chess pieces:
