With the CAD done, we moved on to manufacturing. We started by laser cutting the wooden components. The design was built around 5 mm plywood for almost everything. We used:
- Three 80 cm × 60 cm sheets (5 mm plywood)
- One 50 cm × 50 cm sheet (3 mm plywood)
Here is the cutting layout:
5mm plywood![]() | 5mm plywood![]() |
3mm plywood![]() | 5mm plywood![]() |
And here is the cutting process:
We did run into an issue later with the curved rail plywood gear: the teeth kept snapping off. To fix it, we swapped to 6 mm acrylic instead.
Nasser
