Hackaday.io Hackaday.io
Sign up Log in
Thermal Control of Erbium Dopped Fiber
[thesis; PoC] system to stabilize 10GHz EDFL (Erbium Dopped Fiber Laser) to minimize thermal effects on the modulator.
miniwatt-netMiniwatt Net
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
0 comments
2 followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
Public Chat
134
0
2
1
Team (1)
  • miniwatt-netMiniwatt Net
Join this project's team
shelved project
edfl wdm phase detector controlsystem
This project was created on 02/27/2025 and last updated a year ago.
Description
This project aims to achieve a direct method to stabilize the bandwidth performance of EDFL WDM (Wevelenght Division Multiplex) ring, using a Closed Loop Control System. The feedback path to close this loop is taken from the output of the system and applied in a device that will compensate for thermal and other non linear effects that occur on the system, improving the overall bandwidth performance of the modulation system. The results achieved on the theoretical analysis will them be applied on the physical actuator, controller and feedback path to ensure the real performance of of the modulation system. The results achieved on the theoretical analysis will them be applied on the physical actuator, controller and feedback path to ensure the real performance of the device, acting on an oscillator designed to simulate the frequency to temperature dependency of the real optical fiber system. Everything we have from this project will be provided here, free to use. Kicad V6 was used.
Details
Files
TGI_26_05_2011.pdf
Graduation work from this project
Adobe Portable Document Format - 4.19 MB - 02/27/2025 at 01:20
Preview
Log In/Sign up to comment
Sign up with Github
OR
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Thermal Control of Erbium Dopped Fiber", please tell us the reason.
Send message
Remove Member
