The machine now has hydraulic rams on the wheels for side to side leveling, rams on the vertical and horizontal frames and a tow hitch which is vertically adjustable. Next couple of tasks is to assembly the claw mechanisms and install double acting solenoid, single acting solenoid and proportional flow divider valves and associated pipe work.
GOAT INDUSTRIES
