• Minimum viable product - reading NFCs
    Zalmotek • 03/10/2017 at 11:22 • 0 comments
    The features that I want to develop with the prototype are:
    - Read NFC tags and display their type and UUID values on the display (Done)
    - Access the memory side of NFCs (WIP)
    - Provide simple notifications via RGB led of the state of the device & Buzzer (WIP)
    - Implement storing the read data to the SD card that is present behind the display (WIP)
    Lessons learned the hard way during this iteration :)
    - the breakout board of the PN532 works at 3v3 logic while the shield versions works at 5v
    - the PN532 antenna present on the breakout board has to be 0.7-10 mm further away from other electronic components or battery since it messed with the magnetic field and the range of reading decreases dramatically. Initially I wanted a slimmer case but because of this I had to compromise with another 5mm just so the implant in my hand was read easily. Also to get better reception I did a grove on the back of the device exposing the antenna.
