Hello everyone, this is Imanol, and I'm going to quickly (that's a lie) summarize our project, how it works, but also the difficulties we encountered and the things this project made us realize.
First of all, our project is simply, if you understood correctly, a clock. Actually, at the beginning, let's be honest, we didn't really understand the instructions given by our teacher, and we believed that this clock could simply perform a rotation based on the minutes (for example) and that we could implement many additional features. That's why you can notice in the logs that we had a lot of fantastic ideas like making a thermometer, or a luxmeter or even creating a specific sound for each passing hour. But of course, that wasn't possible, because in reality, we had to build gears to make this beautiful clock, since we actually needed to use mechanics!
(That's when we realized that the first two hours were basically useless... except for making a very nice sketch of our project.)
Finally, after many adventures that you can see in the logs of our project (why spoil it when reading is so interesting ^^), you can see the final result for yourselves.
The problem that we got by doing this project:
Despite all that, we did indeed encounter different problems while working on this project, and some issues are still present today:
One of the biggest problems was sometimes the lack of time we could dedicate to our project. In fact, each week we had more or less important assignments for each subject, which could delay the construction of our clock.
It is challenging for beginners in this kind of field to complete such a complex project, and the fact that the project is made of wood makes the task much more difficult, even if in the end, the project is built with extremely good precision.
We also encountered difficulties with the gears. Indeed, we had never used this technology before. As a result, we had to take the time to familiarize ourselves with the process.
And the most important problem is that we have very poor skills in making projects like this stand upright properly, and that was one of the biggest challenges (I think it was even the case for all the different groups, like for Raphael group).
The good things to remember, finally :
But in the end, there are many good things to take away from this project:
For example, since it was the first time I was working with friends that I already knew (still Imanol writing, but I think it's the same for the other members of my group), I believe it helped to increase team cohesion, which is a very good thing.
Despite the various difficulties, we managed to achieve a rather satisfying final result that works, despite the different points mentioned above.
It helped us to improve our writing skills, as well as our use of Hackaday, which We will surely use for future personal projects.
And of course, our English level has significantly improved by regularly using technical engineering terms with our teachers, which will definitely be useful in our future careers.
This project allowed us to improve our skills in using tools such as the laser cutter, the 3D printer, and others. The same goes for software like Fusion, Inkscape, and the Arduino IDE.
We also learned how to use gears to incorporate indirect motion into our solution
Well, that's it! If you have any questions about how we did our project, you'll find the answers below !
imanolink
Saranpää
Luke Brandon
Happy reading!
