Clock(April 8th)
A project log for Mechanical Clock
A clock
maxandrelenamaxandre.lena • 04/29/2025 at 11:01•0 Comments
With our project back on track, we focused on designing the gear system required to transmit motion from the seconds gear (1 rotation per minute) to the minute gear (1 rotation per hour), and then to the hour gear (1 rotation every 12 hours).
Due to the constraint that no gear can have more than 60 teeth (because our model will be too big otherwise), we had to carefully calculate the gear ratios. After testing different configurations, we settled on multi-stage gear trains to achieve the necessary reductions.
Using Fusion 360, we created digital models of each gear and ensured that the teeth meshed correctly. We double-checked the spacing and pitch diameter for each gear pair to avoid slippage or backlash.
