Part 1 - Fixing Up The Preexisting Code
A project log for Database Designer
Because I don't like having to make SQL every time I want a new database
walkerdevWalkerDev 03/06/2025 at 01:430 Comments
So. I ended up making a large amount of code in the format shown below
This would create the SQL file from text. Atop this, the below code
Would create the documentation required for the database. Pretty good!; i've made over 3.5k lines for a database preset sing this! However, this code is the new issue;
I made a function which allows me to create tables much more cleanly, but this means throwing away all the work I already did in favor of the new function. Still, i'm all for progress so this is what i'm doing! I estimate it'll take 2 to 3 days to setup but I do think it's worth it in the long run! When it's all put together i'll give a more formal introduction.
