I thought folks, especially on Hackaday.io, would appreciate peering into my 3D printing Home Assistant. I have a 3D Printer set up in my garage to print the Traffic Monitor 3D Enclosure. I am new to 3D printing as of a few months ago, so I had no idea when something would go wrong or what my settings needed to be for a successful print.
I also wanted local control and monitor, because I am very conscientious about privacy and security--which I hope is reflected in the open source TrafficMonitor.ai project.
Software and Hardware
Some pieces I used to make this work:
- I set up the Moonraker HA plugin to tap into all the sensors and controls for my Elegoo Neptune 4 Plus (moonraker on klipper, right??).
- I used a couple TP-Link Matter plugs (and block internet access to those plugs at the router-level!!).
- I had to install the Matter HA plugin to gain control of those plugs, but they are now completely within my control within my network.
- Ecowitt Wi-Fi gateway for temperature/humidity monitoring (I have some moisture sensors in my plants outside, so I just moved this gateway into my 3D chamber instead of my living room. 😆)
- Cheap USB webcam attached to the Neptune 4 (enabled via SSH, beyond the scope here).
- Heater is just a small space heater I pipe into the custom-made chamber.
- Custom-made chamber for the Neptune 4 Plus (I'll post on this another day).
HA Dashboard
Besides the obvious Neptune sensor cards I created power control and consumption monitoring cards.
- Power control toggle switches (that are also the power meters) for each the printer and chamber heater.
- Heater-control toggle to tell it to use the automation to keep it between the set high and low temperatures.
- Keepwarm toggle to tell it to run the heater automation script to keep temp even when the printer is not printing. (I use this for pre-warming it on those very cold days).
I had to utilize the Utility Meter helpers to calculate the KWh from the meters, but that worked like a charm! Now I can tell exactly how much power I use (and money I spend) to print each component.
HA Automations
I created settable Helpers to set the high and low temperatures for those scripts (those slider bars). I then used the HA GUI to create a couple automation scripts:
- to turn on the heater; when it dropped below temp AND (status == printing OR keepwarm == true)
- to turn off the heater; when it reached high temp
Conclusion
This setup has really helped me become more comfortable with the 3D printer and helps control the conditions (e.g. chamber temp), so I can figure out and control the environment to make the best prints.
Although I use the Home Assistant dashboard primarily to monitor. When I need fine-tuned control or understanding of what's going on with the printer, I use the Klipper fluidd dashboard. I will typically keep both windows up next to each other.
As a side-note, tale of caution: I am sure this will resonate with folks interested in the recent news from Bambu Lab's attempt to "secure" your printer firmware. Last year, after I left my Chamberlain garage door openers connected to the internet and lost my local control and monitoring because they locked local MyQ API access after an unannounced firmware update, I am particularly caution about manufacturers doing this to equipment I have purchased.
Cheers!
glossyio
