3D printing is quite the science! 🧑🔬 In a past life I worked in a biochemistry lab, so I learned a few tricks I wanted to share.
I keep a lab notebook to better capture and analyze all the research and engineering that goes into it. It requires a lot of attention to detail and rigor that is not my strong suit, but I feel like the very least I can do for myself is collect the details. That way if I finally get it "right", I can see what I did.
The part of the science I really fail at is that I modify many variables at the same time ("Oh... let's change the Speed, temp, and while I'm at it Z-offset"), so I have a hard time telling what changes I did improved or hurt the print. 🤦🏼
Notebook Template
Job printername-nn
**Settings**
Started:
Total Duration:
Name/Model:
Slicer:
Printer:
Filament:
Chamber Temp:
Chamber Temp Graph:
**Outcome**
Quality (1-4):
Sellable?
Image(s):
**Observations**
**Diagnosis / likely problem / explanation: **
**Next steps / changes / corrections / improvements: **
Sample Entry
Here is what an entry looks like:
glossyio
