Today, we presented our project to our teachers. As feedback, they told us some ways we could have processed the making of our project a better way.
In conclusion, we could have used less material for the base and removed some parts of it. This way, it would have created some holders on two sides for Youssra to be able to remove the base easier from the bowl as it can be complicated for her to do it.
They also told us that we could have made more prototypes even if we didn’t have the object. Indeed, we can always try to do prototypes even if we are missing some parts, objects or pieces. We can create pieces we are missing to help us move forward. Some things don’t need measurements, and we could have worked on those for the time we didn’t have the egg breaker, like design. We just must work with the information we have.
And we had a very good question about how easy it would be to wash the base. So, we answered that it normally shouldn’t touch it but if it happens it will be easy to remove it because you first take off the egg breaker and then you clean the base how you normally clean a bowl or a plate.
In the end, they told us it was great that we kept moral and that we didn’t complain even with all the obstacles we encountered.
aurelie.pavy
