In the previous log I made a sound amplifier that can be used to play a sound onto a speaker from line out of a controller or a similar device. Since the Halloween is approaching you could use it play some creepy sounds. Let say you have a crypt where you hear a scream of a tortured soul every minute. This is well-modeled by an exponential distribution with PDF (Probability Density Function):
Integrating this PDF from 0 to a, gives CDF (Cumulative Distribution Function):
The meaning of it is "what is the probability that I will wait a minutes for event to happen". In our case, what is probability that you will hear a scream after a minutes of not hearing anybody scream in the crypt.
Now, how do you turn that into a program?
The process is as follows, first you generate a uniformly distributed number U:
U = random.random()
Equate that to the CDF and solve for a
The intuition here is that we are sampling CDF using a uniform distribution, and converting from probability value to wait time by solving for a.
Here a is just a wait time in seconds (units don't matter) between playing sounds of different tortured souls. Python implementation using pygame for playing sounds shows below how to create a dismal atmosphere using sounds from Dark Messiah Of Might and Magic.
import pygame
import time
import random
import math
import os
pygame.mixer.init()
pygame.mixer.music.load("crypt_main_01.wav")
pygame.mixer.music.play(-1)
sound_fx = os.listdir("sounds")
random.seed(18512158625243168)
lmda = 1/60 # average rate of sound effects
while pygame.mixer.music.get_busy():
dt = -(1/lmda)*math.log(1-random.random())
pygame.mixer.Sound(os.path.join("sounds", random.choice(sound_fx))).play()
print("Sleeping for", dt, "seconds\n")
time.sleep(dt)
The result of that is that the sound effects are playing "at random", but on average they are spaced exactly 1 minute apart (lmda=1/60).
Playing sound effect talios_underground_drip_01.wav
Sleeping for 128.69566205426352 seconds
Playing sound effect womb_pit-spiders2.wav
Sleeping for 77.31571960719558 seconds
Playing sound effect crypt_main_01-voice02.wav
Sleeping for 118.22675017236637 seconds
Playing sound effect a_windgust03.wav
Sleeping for 9.406140801162172 seconds
Playing sound effect talios_underground_drip_05.wav
Sleeping for 143.527373362454 seconds
Playing sound effect karthal_city_interior_rndc_03.wav
Sleeping for 233.31308460867473 seconds
Playing sound effect boat_inside_rndb_03.wav
Sleeping for 34.25852255619906 seconds
Playing sound effect menelag_inside-violins05.wav
Sleeping for 45.78918863544417 seconds
Playing sound effect stonehelm_paokai_int_wind_02.wav
Sleeping for 26.795201242341257 seconds
Playing sound effect kharthal_roofs-thunder03.wav
Sleeping for 40.608196333385564 seconds
Playing sound effect boat_inside-creak01.wav
Sleeping for 79.57805612346229 seconds
Playing sound effect karthal_city_cellar_rndc_03.wav
Sleeping for 7.086597576435293 seconds
Playing sound effect stonehelm_paokai_ext_wind_02.wav
Sleeping for 74.11938743159087 seconds
Playing sound effect goblin_main-bat03.wav
Sleeping for 19.494657143535072 seconds
Playing sound effect talios_inside_no_wind.wav
Sleeping for 56.11492592704442 seconds
Playing sound effect talios_inside-creaks01.wav
Sleeping for 65.92188091086814 seconds
Playing sound effect orc_caves_02_creak_04.wav
Sleeping for 114.70192969525529 seconds
Sleeping for 53.66492417273082 seconds
Playing sound effect womb_03_3.wav
Sleeping for 1.850743553746255 seconds
Playing sound effect crypt_catacombs.wav
Sleeping for 46.001320343673086 seconds
Playing sound effect karthal_city_interior_rndb_02.wav
Sleeping for 30.43711004687171 seconds
Playing sound effect upper_temple_main.wav
Sleeping for 6.600836081999313 seconds
Playing sound effect karthal_gates-bird0204.wav
Sleeping for 53.59866821050122 seconds
Playing sound effect crypt_goddess.wav
Sleeping for 101.2902363567874 seconds
Playing sound effect orc_caves_02_wind_gust_04.wav
Sleeping for 48.05731083376595 seconds
Playing sound effect orc_caves_01_small_river_01.wav
Sleeping for 42.116406568532575 seconds
Playing sound effect karthal_gates-bird0101.wav
Sleeping for 141.33458066209457 seconds
Playing sound effect boat_outside_rndd_01.wav
Sleeping for 23.410817717634007 seconds
Playing sound effect boat_inside-creak02.wav
Sleeping for 105.39932936049989 seconds
Playing sound effect boat_inside_rnde_02.wav
Sleeping for 15.517968358066575 seconds
Playing sound effect crypt_main_03_02.wav
Sleeping for 34.4874963559264 seconds
Playing sound effect womb_03_2.wav
Sleeping for 18.18784523134326 seconds
Playing sound effect orc_caves_02_creak_02.wav
Sleeping for 47.969406439382674 seconds
Playing sound effect crypt_main_05_01.wav
Sleeping for 49.53160356370553 seconds
Playing sound effect temple_stairs_02-tone03.wav
Sleeping for 17.15574922570256 seconds
Playing sound effect a_rockfalling02.wav
Sleeping for 8.342460896115393 seconds
Playing sound effect karthal_gates-dog0202.wav
Sleeping for 2.5383012869378447 seconds
Playing sound effect orc_cyclops.wav
Sleeping for 168.82321786938795 seconds
Playing sound effect karthal_city_interior.wav
Sleeping for 29.775608361974413 seconds
Playing sound effect crypt_catacombs-drips02.wav
Sleeping for 56.719310252147324 seconds
Playing sound effect talios_inside-creaks02.wav
Sleeping for 53.343953975100156 seconds
Playing sound effect boat_outside_rndd_03.wav
Sleeping for 1.9232440582360897 seconds
Playing sound effect boat_inside_rnde_05.wav
Sleeping for 52.789288080099446 seconds
Sleeping for 33.81348866316184 seconds
Playing sound effect karthal_city_cellar_rnda_01.wav
Sleeping for 108.5107399666818 seconds
Playing sound effect orc_caves_01_small_river.wav
Sleeping for 88.70394974369471 seconds
Playing sound effect karthal_city_cellar_rndc_02.wav
Sleeping for 46.65599424100057 seconds
Playing sound effect karthal_city_cellar_rnda_02.wav
Sleeping for 79.43392968844216 seconds
Sleeping for 36.106667120965014 seconds
Playing sound effect orc_caves_01_small_river_02.wav
Sleeping for 15.475057283089406 seconds
Sleeping for 95.70672679528789 seconds
Playing sound effect karthal_gates-dog0102.wav
Sleeping for 183.84268891105916 seconds
Sleeping for 28.177534459415273 seconds
Playing sound effect necropolis_goddess_voices3.wav
Sleeping for 7.271903475243708 seconds
Playing sound effect stonehelm_fire_explowood_01.wav
Sleeping for 85.2453587303634 seconds
Playing sound effect stonehelm_fire_explowood_04.wav
Sleeping for 7.432176949246249 seconds
Playing sound effect temple_stairs_01.wav
Sleeping for 75.08470818533749 seconds
Playing sound effect karthal_gates-dog0304.wav
Sleeping for 36.72286949890331 seconds
Vlad Shcherbakov
