8-Channel, stackable I2C Relay Shield for Arduino
Up to 8 Arduino MEGA2560 / UNO Shields for max. 64 addressable relays.
Public Chat
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Starting from
has orders / reviews
Ships from
The shield is compatible with most 3.3V and 5V Arduino modules and can be powered directly from the Arduino’s 5V line. For 3.3V modules, an external 5V power source can be connected for optimal performance.
All SMD parts are already assembled. Only the through-hole components (relays and connectors) still require soldering. The available Arduino library and sample code ensure a quick and straightforward setup process.
This 8 Relay Shield for Arduino is perfect for building intricate home automation systems, sophisticated control mechanisms, or for use in educational projects. It’s a reliable and efficient choice for bringing your creative and complex ideas to fruition.
