Project To Simplify Tying Shoelaces
This project aims to make tying shoelaces easier. The target users are disabled people with hand deformities.
Our project is a small clip that can be attached to the center top of the shoe. Both sides of the shoelaces must cross each other inside the clip. If the user wants to make their shoelaces tighter, they can simply pull them from both sides. And if they want to take off the shoes, they can take the clip off with one hand without struggling.
We met Diego who is a 12 year old kid with a malformation in his left hand. After discussing a bit with him, we decided to try to make an object to help him tie his shoes. Then, we came up with an idea, which is to create a clip that will hold the laces in place and also allow him to tighten his laces. We got the inspiration from multiple objects such as; plastic boxes and bracelet clips.
Prototype Photos Log 5.docx
document - 479.16 kB - 04/08/2025 at 14:18
Download
The Reference Photos.docx
The photos of our prototypes mentioned in Log 4
document - 580.12 kB - 04/02/2025 at 10:17
Download
  • 1 × Plastic
  • Log 5 (04/08/2025)
    nurdamla04/08/2025 at 14:18 0 comments
    Today we received our first 3D printed prototype! We assembled it and immediately noticed some flaws. The hinge is not printed as a perfect circle. This is because of the way the 3D printer prints. So, when we tried to attach the hinge with the ink container of the pen, we couldn’t insert the container into the hole. And even when we hardly did, the hinge could not move. There is also another reason for no movement: the clip. The clip works when we close it, but we cannot open it back. We figured that the reason for this was because the material is too hard and not flexible. This isn’t that bad since we also need to make our prototype durable.
    So, the focus for today is to make an improved version of our prototype to 3D print it along with the second prototype. For the improved version of our first 3D printed prototype, we concluded that we need to make the diameter of the hole around 1.5 mm bigger (new diameter: 4.5 mm).  We also agreed that the length of the base is too long and decided to make it shorter for the improved version.
    Update: We tried the prototype even though the hinge part doesn’t work. We saw that the shoelace wasn’t holding well. It slid easily from the prototype. This means that the opening is a bit too large for the shoelaces.
    The photos of the prototype are in the "Prototype Photos Log 5" file!
  • Log 4 (01/04/2025)
    nurdamla04/02/2025 at 10:15 0 comments
    Today we are working on the prototypes and thinking of getting them ready for next week. This is because next week our user Diego will come to the lab to test our prototypes. We have been told to make more than one prototype to pick the best working one.
    Last week at the end of the course even though we had a prototype ready, our teachers said that 3D printing a small hinge won’t be durable enough and will easily break after a few uses. They have recommended us to use an already existing object for the hinge. We found today that the best working object seems to be the ink containers inside pens. The size is appropriate for our project which made it the most suitable option.
     Update: We showed our prototypes to the teachers and there was a slight problem with the sizing (1a, 2a, 3a). We chose a 0.5mm thickness which is not durable enough and hard to print with the 3D printer. To guide us, the teacher gave us an object that contains all the thickness. This object (A, B) gave us a better understanding of the sizes we should use for our prototypes. The fixed version of our prototype has now a 2mm thickness(1b, 2b, 3b).
    Update: We showed the fixed version of our second prototype but there was another slight problem with the clip that we wanted to do(1c, 2c, 3c, 4c). It turns out that it is more complicated than we thought. For the solution, the teacher sent us documents to guide us and visualize the geometry we need to use for the clip. We changed the shape of the clip with a better geometry(1d, 2d, 3d).
    All the photos are included in the “The Reference Photos” file.
  • Log 3 (18/03/2025)
    carlie.vong03/18/2025 at 15:32 0 comments
    Today, we worked on our prototype on FUSION 360 and we think that we have our first printable prototype.
    We know that this prototype 1 isn't going to be our final project but we still hope that it still can be used.
    We decided to make the clipper ( prototype ) in 3 pieces, two for the main parts (up and down) and the last part is to link the piece together.
    Then we'll have to add 2 more pieces inside the clipper because that's what is going to hold the laces.
    Here's some examples of material and how it's going to help us holding the laces in place :
    - if we use rubber, the 2 pieces of rubber will get squished against each other and with the laces in between it won't move.
    - if we use plastic again, then we'll make some pics in a certain direction to allow the laces to be tightened without allowing them to get loosened. (but this idea doesn't seem practical because both laces aren't going in the same direction.
    Here's the dimension of our printable prototype 1 :
    - length : 2 x 3 cm
    - depth/height : 1 cm
    - hinge : ~ 3cm
    Here's how our prototype 1 is :
    For the next session we'll try to 3D print it !
  • Log 2 (25/02/2025)
    nurdamla03/17/2025 at 15:23 0 comments
    Today we focused more on our prototype and the feedback we got in the previous session. And thought of ways to improve it.
    Summary of the first try of the prototype :
    At first Diego didn’t know how to use it without explanation
    Then we explained to him how to use it and he had trouble putting the laces in it as said in LOG 1.
    So we should put some small intersections for the laces so that the laces do not move.
    We noticed at first that he had trouble pull the laces
    But at the end we saw that he could do it
    More details on our prototype (for now) :
    Made of two pieces in cardboard :
    In rectangle one large and one skinny to imitate the clip.
    Some rubber band
  • Log 1 (04/02/2025)
    nurdamla03/17/2025 at 15:20 0 comments
    Creation For Diego’s Laces
    For who?:  For Diego
     Problem: He can’t tie his shoes.
     Solution: The solution can be to create an object to help him tie his shoes by replacing the tying and untying part.
     Imrovement: The prototype needs to hold a bit the laces so that they don’t go everywhere and make it even more difficult for Diego.
    Feedback we received :
    Diego seemed to have trouble keeping the laces in the same place when putting the prototype on. So, it would be nice to add some small insertions for the laces. Then it would be nice to have a better clip to open and close the prototype.
View all 5 project logs
Rich text editor
