Simplification
A project log for typeCAD
programmatically create hardware
typecadtypecad • 05/31/2025 at 05:54•0 Comments
typeCAD was growing in features at the expense of simplicity. The entire API has been simplified and the interaction between KiCAD and typeCAD has been improved while also maintaining backwards compatibility.
Schematic and PCB
The Schematic and PCB classes have been merged into a single PCB class. The PCB class now has a schematic property that contains the schematic data. The PCB class also has a create method that takes a list of components and adds them to the schematic and board. This change was made because the schematic and board are always created together and there was no need to have two separate classes. Also, typeCAD was the schematic, so why put any mental effort into another ‘Schematic’?
Now the bare minimum code to create a board is:
import { PCB } from '@typecad/typecad';
let typecad = new PCB('typecad');
typecad.create();
There’s no need to think about Schematic anymore. All the functionality is still there, but it’s stubbed out in the PCB class. ::net and ::named are called from PCB now. So is ::bom and ::erc.
KiCAD
The interaction between typeCAD and KiCAD was getting unintuitive. Wondering if you needed to Revert to see component location changes or reimport the netlist to see other updates was confusing.
Now, typeCAD will automatically import the netlist after running PCB::create(). That means you never have to interact with the netlist file again.
Any changes made to the board will be reflected in their entirety when you run PCB::create() and use the Revert function (or just reopen) the board in KiCAD.
More KiCAD integration to come
Soon, we’ll be releasing a new version that will check for a dirty .kicad_pcb file and prompt you to revert before running PCB::create(). This will prevent any changes you’ve made in KiCAD from being lost. It will be more robust and useful that the current method which just checks for the existence of a lock file.
Package improvement
We’ve tweaked things to make packages easier to create and use. They are now created similarly to other components, and also used the same as well. Before, our example packages had add and place methods. Now, they have a property that holds everything in a components array. That array is passed to PCB::create() as a spread operator. The result is a much simpler and more intuitive package creation and use.
npm update
Update your projects and packages to the latest version to get the latest features and improvements.
