log ugh
A project log for Raspberry PI Zero with Qualia displays
I love the qualia displays that adafruit has
davedarkodavedarko 04/22/2025 at 11:190 Comments
My LED driver was not correct, I burned the backlight of my display when accidentally hitting the memory button of my power supply, sending 60V to my Display woops.
Took me forever to put two code examples for the PIOs together. Now I'm back to using the Qualia board to send the commands first and then see if the Raspberry is sending the right info at least. no dice yet, might have to connect the reset pin.
I'm thinking about designing V2 of the board now, before endulging all of this.
