- 101 Water Container Front Handle
- 102 Programme Knob Switch Dial
- 104 Module-control
- 105 Capacitor Main Interference Filter Interference
- 106 Power Cable Lead Wire & Plug
- 107 Panel facia
- 199 Repair-set
- 201 Panel side
- 202 Panel side
- 204 Hood
- 205 Heater Cover Panel Seal
- 206 Heater Element
- 207 Temperature Limiter Sensor NTC
- 208 Thermostat Temperature Limiter
- 214 Door Lock
- 215 Seal
- 216 NTC Temperature Regulator Thermostat
- 219 Bearing
- 223 Fluff Lint Mesh Filter
- 227 Door Catch Lock Cover Plate
- 228 Door Seal
- 230 Worktop
- 231 Drum Roller
- 402 Drive Belt 7 PH 1992 7PH1992 (£14.95)
- 403 Drum Bearing
- 405 Felt Drum Seal
- 407 Drum
- 410 Taper
- 501 Adjustable Foot / Leg
- 502 Motor
- 503 Spring
- 504 Roller Tension Belt Pulley Wheel £8.25
- 506 Fan Impeller Drum Wheel
- 507 Fan Impeller Wheel
- 508 Capacitor 8uF
- 512 Water Pump
- 513 Hose connection inlet
- 516 Condenser Water Container
- 517 Hose fill
- 518 Cover
- 519 Cover
- 520 Water Condenser White Cover Flap
- 521 Lock-mechanical
- 522 Heat Exchanger Condenser Unit
- 525 Hose recirculation
- 526 Lid
- 532 Case-bottom
- 534 Filter
- 535 Hose-fill
- 536 Cooler
- 550 Drain Hose
- 551 Holder
- 552 Connection
- 554 Hose fill
- 8401 Instruction manual
- 8402 Instruction manual
- 8404 Warranty certificate
Keith
