• Improvements
    Michael Schembri2 days ago 0 comments
    1. Applying toner method using spray method or maybe immersion method (help needed)
    2. Use faster settings in the grbl during laser firing. F30 is slow and heat might be propagating outside of point of incidence. Therefore more toner is melting than required.
    3. Change flatcam to fire tracks only once. Isolation tracing fires each track segment twice.
    4. Reduce pad/via size
    5. Once visually acceptable, one can also try to etch this.
