New feature requests
A project log for Valgrind output parser with source code
A simple command line application that parses the output from Valgrind and presents it in human readable format with source code references
john-andersonJohn Anderson 05/13/2025 at 18:350 Comments
I added two issues in github requesting new features.
The first one is to refactor vgp to use universal ctags to parse the source function from the source file. This would simplify the vgp source code and expand the supported source languages significantly.
The second one is to support Valgrind's xml output. This could simplify the parsing a bit. But, more likely it could future proof vgp. It's less likely that Valgrind will change it's xml output formatting.
